OK I have a bit of a problem with weight and want to add a pair of batteries and a/c. this would add 150lbs onto my van and put me over the weight restrictions I have with FedEx.
After searching EO for the thread discussing the 400 lb exemption – which I could not find – I decided to download the energy bill and look for the exemption.
After reading the provision, I find that it does not specify a unit that has to do all three – heat, cool and provide electricity but rather all or each – which means generators are also included.
I also was disappointed to read this was for only heavy duty truck but they defined it as 8,500 lbs GVW and above with a diesel engine – so I am safe. The only catch I can see is acceptance with emissions, hence the EPA and title 40 involvements, but I don’t think that matters with new equipment. The interesting thing is that it does define the APU as integrated which I take that as exclusive power and environment source outside of the main power source (van engine) but does not rule out module system made up of different components not located within one package.
So here is my idea - I have a small (less than 80lbs) one cylinder diesel engine and a Leece-Neville 200 Amp alternator with internal regulator – which I think the alternator weighs as much as the engine. I want to put these two together and mount it underneath with two batteries and an inverter within the van (to be zero emissions at some locations) with an A/C unit on top, etc… I think the total weight addition would be around 250 lbs.
This means that the batteries/inverter are in one location, the generator is in another and the A/C is in a third but completely and totally separate from the main power source (van engine).
Any ideas or comments?
