Question on pay
Riffsimm
Just curious, is the 60/40 split based on what is paid to the truck for the entire run, Or a set per loaded mile rate ?
Tobster317
If it was me. I would want 100% of the fuel surcharges (60/40 assuming you are paying for fuel). 100% of tolls if you are paying them, 100% on hazmat loads.
If it's a fair split it is 60/40 of the loaded miles pay with 100% of the FSC going to the side that pays for fuel and gets the 60%. Beyond that it is open to debate. Deadhead pay is usually not a lot above the actual cost of fuel and usually doesn't start until after 50-100 miles. I gave 80% of the DH pay to the 60% side to help with fuel cost and 20% to the other side. Detention and layover pay are time compensation. Time is the same for everyone. That was split 50/50. Hand load/unload, inside delivery, etc. are pay for labor. That went 100% to the drivers as they did 100% of that work. All of that and more should be spelled out in your contract with the truck owner.
Reactions: TDave and Treadmill
Tobster317
I would say weight the truck and you (and your stuff) and full the fuel tanks. Then whatever your gross weight is minus that and that’s what you can carry. I would leave some wiggly room.
FlyingVan
I met a guy a few years ago in an under CDL straight and he could carry 8500 lbs. His box was either 16 or 18 feet long though, don't remember which.
