QC messages
golfournut
Usually when a load offer is sent, 3 messages are sent at the same time. The 3rd being pay info.
I had an issue where the pay info did not come across. Had it made it I would not have accepted the load.
I had a meeting with Mike Bayko and according to his system, the msg was sent as normal with the time stamp. I only received 2 of the 3 msgs.
I noticed this has happened a few times on my truck also. Only the pay part doesn't come across.
According to Mike, there is something wrong with my QC.
Was wondering if anyone else has seen this or is there a problem with the 2 QCs.
Thanks
shadow7663
Thanks
I have that happen often, with that said when I get a call about the load I just ask about the rate also.
It really wasn't a problem until I put a driver in my other truck because he forgets to find out the rates, they are not sent via QC and when I log on to fleetvision the rates are not in the system. Then he has no idea what kind of money he is making.
Then my QC must be broke as well.....I don't get the money message at times as well....
OH...JuJu checks my fleetvision all the time...Messages show only 2 sent...???
jelliott
Motor Carrier Executive
Unless it is a split load where the rate has to be calculated out, this should not happen. If you see this in the future email me the load numbers and I can have it researched. I doubt it is the qcomm. More likely the dispatch software, unless this is a manual step and then more likely the operator.
It happens on Great paying rates as well as lower end rates as well...so I don't think there is a conspiracy going on..
It seems to be random...
RoadKing06
There are several times we have to request the rate because we don't get it with the load. We have noticed if it is a split load that it has taken much longer to get the rate.
There have also been a few times after seeing the rate wished we hadn't said yes to the load. It has been more that way the last couple of weeks. We don't turn loads down, so starting to think that we get many of the ones no one wants. Hopefully it will pick up better soon.
It all equals out in the end. We were able to pay our bills in July by staying rolling. Many said they were sitting most of July. So we don't complain, just roll with it.
For me anyhow down here in the smaller guys....when a rate comes thru for a CV load ..I think..What?? Less then a buck!! How cheap is that? BUT then I think if I were with my old carrier less then a buck is standard!:rolleyes:
Me thinks I am spoiled by the higher rate now...:D
chefdennis
Its not about not sending the pay info when it is a lower rate...as was pointed out, it happens with great rates also...it does happen and more then one would think it should...but you know what, when I call in to have the pay screen sent, i have yet to have one i would have turned down....and beyond that, it goes back to the "trust factor"...and I trust em....:)
That is what I was saying...even the low ones are higher then with the old carrier...and if they happen to bid low..many times WITHOUT even asking they've topped off the percentage on our end to make things right...
RoadKing06
We trust them as well, that's why we don't turn anything down. Some are just lower than others. Things have been on the lower side lately is all I was trying to say.
We expect it to get back up. We haven't had any home runs lately. We are due and it will come.
It does happen fairly often but I just send a qc message asking for them to send pay info on current load. Once in a while I have had to ask two or three times. Maybe a little irritating but no big deal.
I am not sure what the difference between little on big trucks is but don't you accept or not accept a load before the info is sent on the qc? If you already said yes on the phone in my book changing it to a no after the pay info is received is not very cool. If a person is concerned with the pay then they need to ask on the phone imho. I have turned down very few loads and do not ever remember pay being the main reason for doing so. I have never seen a load in a sprinter that was not profitable. Some might be a little less so than others but bad enough to turn down based on money alone I have not seen. There is a give and take involved in this business.
RoadKing06
Agreed, would never turn down after already said yes. Always say yes when the phone rings, never ask what it pays. We like suprises. With not being the owner of the truck, the pay sometimes leaves us saying oh well. But I ouldn't want th truc expenses that goes along with owning the truck. So it all works out in the end.
IF it is warranted don't you think a call to dispatch asking for a bit more percentage for the owner would be prudent on the lower runs? after all the owner has to maintain that truck....you might get your share, but what is left for the owner?
I do that on marginal loads...sometimes I get a bit more %, sometimes not....
RoadKing06
I have asked once or twice before, wasn't wanting to shake the boat, so I don't. Maybe I will more since it is considered acceptable to do so, at least that is the way I am taking the last comment OVM.
Thanks
I have never found a need to ask what a load pays. I might have asked once or twice if it is a cargo van or sprinter load.
Wolfeman68
US Marines
I asked what the load paid when I first started with Load 1, but after seeing what every load paid, I stopped asking.
I do prefer seeing the revenue message though so I don't have to look on Fleetvision. When my drivers complain that they didn't get it, I tell them to send a QC message requesting the revenue message.
golfournut
I never ask what it pays either, but I like to see it with the load offer. Occasionally when I was in the truck I asked them to bump it up a little.
The load I am referring to that I had the problem with ended up at about .70all in/ mile with DH. On the very low side I would say.
I did ask for it to be sent once or twice, but never got. Still haven't, but it's on FV so don't need it now. A little too late to ask for the bump after its delivered.
Thanks
It is not unreasonable to ask...and it is not "rocking the boat" sometimes dispatch is real busy and doesn't think of certain circumstances...you could discuss your concerns if you think the load is a little low....
golfournut
Absolutely, but I don't mind taken one for the gipper once in a while. It was only 175 load but about 250 all in. Got me to the yard to debug me and the van. The QC issue is my concern after talking with Mike.Didn't ask for it, but got a load home afterwards, so the boss is happy. As we all know, when the boss is happy, its allll gooood! *l*
