The GVWR of the van is 8,600 lbs, fully loaded, fuel, and passengers. I am gonna find out what the truck weighs empty. The most I will be hauling will be 2,000 lbs. Give or take 500 lbs. Even if the camper weighs 1,600 lbs, which it won't, I will still be well below the 10,001 lbs. So I am not worried about the weight. I will be asking the company that I will be working for if they have a problem with me towing a SUPPORT/CAMPER behind MY truck. I do appreciate all the input on my idea, thank you. Nobody seems to like it but, oh well. I have been a Courier/Expediter here in the Charleston SC area for the last 2 yrs. If I decide to do this full time, out on the open road, I want to make it as comfortable as I can for myself. It might seem petty to some, but frankly, truckstops are disgusting.
Since you've showed your disdain towards many of the comments you
asked for here, I'm going to go ahead and point out what the obvious is here.
You have no idea as to what it is you're getting into when it comes to running OTR.
First off, you spout off the 10,001 weight class that is for CDL "LICENSING", Not Vehicle weight classes.
Second clear example is what you posted above. You say your vans GVWR is 8600. In order not to be running as a combination vehicle and under 10,000 lbs, your trailer must have a total GVWR of less than 1399 lbs. There is not a Travel Trailer out there equipped with all the amenities you seek (shower-toilet-fridge-AC-Generator-etc) that is under, say, 2800 GVWR. Sure, your trailer sitting there may have a dry weight of 1600 lbs, but once you start adding your personal belongings, filling the tanks with water, adding propane tanks for the stove, generator, and heater, filling the fridge and cabinets with food, and so on, that trailer is going to hit the 2000-2200 lb range very quickly. AND, that is why the GVWR of that trailer will be set at 2800. My bet is the trailer itself probably has a 3500 GVWR. That's usually the lowest "axle" rating one can get for a TT set-up that just has a single axle.
Now, take the 8600 GVWR and add the 2800-3500 GVWR of that TT together and you will clearly see that YES, you are in the "combo vehicle" class running well over a combined weight of 10,000.
So, take a step back, edgeumacate yourself a little better when it comes to rules and regulations when it comes to running OTR, and then come back and ask questions about stuff you have little knowledge about.(or more than you do now) As of right now, you're really not worth anyones attention here. IMO of course......
