Just to give you a heads-up. If you find some day that you cannont send photos to someone as they receive a message "the photos are expired, contact the sender for more information" don't start messing with your computer. MSN does not know where the problem is and I understand that some other providers may be having the same problem.
If you do have the problem, just google the above comment and you may find a correction. As of now there is none. If you want to find out if yours still works, using the send photos command (if you are using MSN, don't know about the others) send several photos to yourself in one email and then try to open them up on the slide show. Good luck.
TR
TR
