Congrats Phil (aka Ateam) on their new truck and the article, Looks nice.
Phil in all honestly I am really courious to learn a couple things.
I am wondering why a day cab and adding a sleeper to it? Wouldn't it been better to use an intergral sleeper and have the work done to lengthen it to your specs? The cost may have been less than you think. I seen a number of these done really well (being critical of body modifications myself) and even with Air ride suspension to give a smoother ride in the sleeper.
The other question is front axle wieght, is 11,620lbs cutting it really close? I thought that the state limit was generally 12K sometimes even higher, which I assume that if this is correct, putting a load on say 6000K will shift more than 400lbs to the front axle causing an over weight situation on the front axle? Please correct me if I am wrong.
