Overheating
pellgrn
I have a baby cat 3116,i think.My driver says engine runs real hot at speeds of 55mph and above and when the weather is 90 or hotter.I said to put the heat on,he does and it helps alittle.If he idles its fine,there are no leaks inside or out.I wanna take the thermosat out and see what happens,what do think?
rode2rouen
>real hot.........
How hot is "real hot" on the Engine Temp. guage?
Does the fan clutch engage when it gets "real hot"?
Rex
Stone Expeditors LLC
(941) 286-2558
Advertiser
Immediate Opening for Team Expedite Straight Truck
The best fleet in trucking is seeking a couple STRONG TEAMS to fill the seats of our new straight trucks with large luxury custom bolt sleepers and all the amenities. The market is back, the money is rolling in, and the wheels just keep on turning! Direct deposit every Friday. No deductions, no micromanagement from fleet owners or managers. Flexibl ... Apply Today!
I would agree with Rex. Sounds like a fan clutch as they do go out on these engines. Other possibilities are the heat sensor or a plugged radiator.
owner
22 years
PantherII
EO moderator
pellgrn
Thanks for the feedback,is there a way for the laymen to diagnose if the fan clutch is bad? he's laying over in w memphis is there a decent garage out there open on a sunday.
rode2rouen
There are 2 types of fans that are commonly used.
Air operated: these are found on most class 8 engines (as well as some newer class 7s) and the fan function is controlled by the ECM as it monitors coolant temp. On older mechanical engines there was a fan thermostat (commonly called a "Skinner Valve") that controlled the air. You can usually see the 1/4" air line going to the front or rear of the fan hub.
Viscous operated: these use the flow of air through the radiator to activate the fan. When the temp of the air coming through the radiator reaches a certain point the fan engages (this is usually tied to the engine thermostat opening temp).
Trouble shooting is straight forward....with either type you should HEAR the fan engage when the engine thermostat opens. For example: my International with an M11 Cummins will usually run at 180 degrees, when the temp reaches about 190 under a hard pull, the fan will come on and stay on until the engine temp drops below 190.
You really need to have the driver give "real hot" a temp number...is "real hot" over 220 degrees?????
Note: there are also electric controlled fan hubs, but they are usually found on school busses.
Rex
pellgrn
He said 210 is the highest it gets,i think i'll have him take a power hose and blow the bugs out the front of the radiator cause it only gets over 200 when he turns the air on,the condensor gets hot and there's not enough flow to compensate.If he idles or drivers with the air off he's fine,if the fan clutch was bad it should heat up even more at idle i would think.Thanks again for everones input.
Not exactly. It sounds like the fan clutch. A distant shot is the heat sensor on the side of the radiator.
owner
22 years
PantherII
EO moderator
Broompilot
I agree with Pell thats also the cheapest solution to begin with. If that still does not do it use any Oven Cleaner let it sit (Cool) for about 20 minutes than rinse completely.
If still having heating concerns, than consult a professional. Cooling is nothing to play around with.
(941) 286-2558
Advertiser
