New to expediting
Skywayne
Can this be done part time here from/on the west coast based in Southern California with a cargo van or sprinter, with a class C license (non CDL)?
Gary, Claremont, Ca.
Doggie Daddy
Not likely,you may pick up a few dollars here and there but I doubt it would be enough to make it worth the effort. JMHO.
FIS53
I would imagine there would be quite a bit of hot shot business from several industrial/warehousing areas that could be run in a van/sprinter. There are several companies where I am doing such and the pay isn't too bad provided you can garner enough calls through the week (can't base on a day).
Rob
Dakota
Your best bet for part time work is to go look at air freight/air freight forwarder type companies. ie Bax/Schenker, Ceva Global, even DHL, UPS Supply Chain. Fedex Ground/Home delivery and many others that I cannot think of or don't know about.
You will need your own authority, if you have a cargo van and are thinking about this you might try going down to the airport area, most of these type companies are near an airport and talking to the terminal or operation manager. Also check with the local courier type companies. i'd even get some business cards printed up with your company name "Acme expedite" LOL
Pass out ten or so to each of the businesses you visit and then they can put them up on their bulletin boards at their desks, that way you will always be on their mind.
You will need to do research on price to charge etc. I'm not the one to ask as far as getting your own authority etc. Just giving you some ideas to think about
