From what I heard on the last conference calls was if you aren't a W.G. division truck you are now a discount truck. question ask are TSA, DOD, WG, HAZ and radiation load discount loads and they said some are but you will get a nickel more a mile (hope that's on DH & run miles both) then why have the endorsements fedex said they would get you better paying loads. this flat rate was to cover surfaces loads now it seems to be all loads. So if I take a W/G load and use all my W/G equipment l/g, more then 4 strap, bars & blankets I get a .05 added/mile. is this right. I can see if you have the bare min. equipment and only can respond to bare min. loads then you should be receiving the new flat rate and the loads are bare min, loads. But when you go the extra mile with equipment & endorsements and the load is paying for these services then it should be sent out at the same rate it is sent to the WG division trucks. fedex said the computer cant do this because your truck to the computer can only see you as a discount truck. I disagree these loads go thru different division and could be flagged as TSA,WG,DOD,HAZ & Rad loads. To me this should show fedex the bare min they should be charging for these loads & added services not force our paid down and drive more miles the make up for the lower rates and preform the same services. Which is CUSTOM CRITICAL not Common Carrier
