I recently purchased an FL70. To be honest, the reason for choosing this truck was strickly economical. The truck will be used 6 months for my "other" business and then 6 months for expediting. If things work out, I will replace this truck in about 2 years and would probably go with another make (Pete, WS, KW or Freightliner 106).
The truck is a 1998, with a 22.5' box, 60" sleeper, Cat3126 and a 6 speed Eaton trans. It has 375,000 miles, and everything (engine, trans, drive train, electrical etc.) was checked out by my mechanic.
This was a repo, and I picked it up from Mercedes Benz Finance, through a Freightliner dealer, for $16,000+. That included new windshield, complete detailing, and every item on DOT test that required repair, was fixed.
Freightliner is currently stuck with a lot of used and repo expediter trucks. If you shop around, there are great deals out there for a first truck.
With the reposessed truck, it appears to work this way.
The Freightliner dealer is paid storage for keeping the trucks on their lot. When the bid is accepted, the salesperson gets about $200 for selling the truck. If you are purchasing a repo, you want to find out if the dealer made a rejected bid to Mercedes Benz, and find out what the amount was. Ask the dealer what they had requested Mercedes Benz to repair, replace etc. on the truck, when the bid was submitted. That way you have a chance to find out (maybe) what the dealer felt needed to be repaired. You can then put all of that together and make your own bid for the truck. They will probably make a counter offer.
Hope this helps. Good luck. Larry
