actually...No...it's just one carrier borrowing from another....lately 2 known little ones have ceased operations and probably many more....and not one offer anything different then the others...the bottom line the O/O out here is no further ahead...no matter the hype one drums up...There is NO strategic advantage to running multiple carrier....
I have to disagree OVM. Most companies that have failed, have not failed because of the lack of frieght but more because of mismanagement. Are there companies out there that have prospered and grown? Sure there is. Most companies in most industries don't succeed but some that you call "little ones" will end up being industry leaders.
As for NO strategic advantage for running for multiple carriers... I would be willing to bet that 80% of the cargo van drivers that drive for one carrier, had a lower net than I did running for 4 to 6 carriers this year. No mattter where I went I was first out with a couple carriers and less days sitting does equal a higher net as long as you are not running for peanuts.
It's not how much you run and
It's not how much you run for,
It's how much you get to put in the bank...$$$
