Military wit and wisdom
louixo
Wit and Wisdom from Military Manuals, etc.
"A slipping gear could let your M203 grenade launcher fire when you least expect it. That would make you quite unpopular in what's left of your unit."
- Army's magazine of preventive maintenance.
"Aim towards the Enemy"
- Instructions printed on U.S. Rocket Launcher
"When the pin is pulled, Mr. Grenade is not our friend."
- U.S. Marine Corps
"Cluster bombing from B-52s is very, very accurate. The bombs are guaranteed always to hit the ground."
- USAF Ammo Troop
"If the Enemy is in range, so are you."
- Infantry Journal
"It is generally inadvisable to eject over the area you just bombed"
- U.S. Air Force Manual
"Whoever said the pen is mightier than the sword obviously never encountered automatic weapons."
- General MacArthur
"Try to look unimportant; they may be low on ammo."
- Infantry Journal
"You, you, and you. Panic. The rest of you come with me."
- U.S. Marine Gunnery Sgt. (Mgysgt5)
"Tracers work both ways."
- U.S. Army Ordnance
"Five second fuses only last three seconds"
- Infantry Journal
"Don't ever be the first, don't ever be the last, and don't ever volunteer to do anything..."
- U.S. Navy Swabbie
"Bravery is being the only one who knows you're afraid."
- David Hackworth
"If your attack is going too well, you're walking into an ambush."
- Infantry Journal
"No combat-ready unit has ever passed inspection."
- Joe Gay
"Any ship can be a minesweeper. Once."
- unknown
"Never tell the Platoon Sergeant you have nothing to do."
- Unknown Marine Recruit
"Don't draw fire; it irritates the people around you."
"If you see a bomb technician running, follow him and try to keep up."
- USAF Ammo Troop
"You've never been lost until you've been lost at Mach 3."
- Paul F. Crickmore (test pilot)
"The only time you have too much fuel is when you're on fire."
"Blue water Navy truism: There are more planes in the ocean than submarines in the sky."
- From an old carrier sailor
"If the wings are traveling faster than the fuselage, it's probably a helicopter -- and therefore, unsafe."
"When one engine fails on a twin-engine airplane, you always have enough power left to get you to the scene of the crash."
"Without munitions, the USAF would be just another expensive flying club."
"What is the similarity between air traffic controllers and pilots? If a pilot screws up, the pilot dies; If ATC screws up....The pilot dies."
"Never trade luck for skill."
The three most common expressions (or famous last words) in aviation are: "Why is it doing that?", "Where are we?" And "Oh S...!"
"Weather forecasts are horoscopes with numbers."
"Airspeed, altitude and brains. Two are always needed to complete the flight successfully."
"Mankind has a perfect record in aviation; we've never left one up there!"
"Flashlights are tubular metal containers kept in a flight bag to store dead batteries."
"Flying the airplane is more important than radioing your flight to a person on the ground who is incapable of understanding or doing anything about it."
"The Piper Cub is the safest airplane in the world; it can just barely kill you."
- Attributed to Max Stanley (Northrop test pilot)
"A pilot who doesn't have any fear probably isn't flying his plane to its maximum."
- Jon McBride, astronaut
"If you're faced with a forced landing, fly the thing as far into the crash as possible."
- Bob Hoover (renowned aerobatic and test pilot)
"Never fly in the same ****pit with someone braver than you."
"There is no reason to fly through a thunderstorm in peacetime."
- Sign over squadron ops desk at Davis-Monthan AFB, AZ, 1970
"If something hasn't broken on your helicopter, it's about to."
Basic Flying Rules: "Try to stay in the middle of the air. Do not go near the edges of it. The edges of the air can be recognized by the appearance of ground, buildings, sea, trees and interstellar space. It is much more difficult to fly there."
"You know that your landing gear is up and locked when it takes full power to taxi to the terminal."
As the test pilot climbs out of the experimental aircraft, having torn off the wings and tail in the crash landing, the crash truck arrives, the rescuer sees a bloodied pilot and asks, "What happened?".
The pilot's reply, "I don't know, I just got here myself!"
They once had a jet plane in Flight Test that had a complicated 8-step process to eject the pilot from the plane in case of an emergency. To make sure the pilot could see it in the even of needing to eject, the 8 Steps were placed just above the pilot's head on the inside of the canopy.
Step 1 - Eject the canopy
I love it!! The Soviets never used to put ejection seats on thier test aircraft, lost a lot of test pilots that way!! We used to keep "score" on a chalk board in the one office I used to work in.
The above story, incidentally, was relayed to me by one of the test pilots who's job it was to catch little things like that. That man went on to be one of just 24 men who have flown to the Moon. But he is not well known, even though his Moon flight was the most famous one of all, as he had possibly the ultimate in "it's a dirty job but somebody's gotta do it" as the Command Module Pilot who orbited the Moon as others walked on it for the first time in history.
RTOspeedwagn
- Infantry Journal
"Not if youre behind a Rheinmetal 120mm main gun."
-Armor Journal
mjolnir131
- Infantry Journal
-Armor Journal
actually the M68 main gun(a 105mm) in a A3w/tts is a better example of the exception to that rule. The Leopard 2 and Abrams both are hard pressed to hit a target at 9000 meters just under 50% of the time, while an M60A3 can plink at that distance all day and not miss.
The l55 is a great cannon but the fire control is a bit lacking that is where they cut cost
