moose
Mega destruction :
How stupid can you get ? , well this Arab flight crew will show you.Photo show total destruction of 200 Million $ Aircraft brand new off the assembly line,
THE TALE OF THE ARAB FLIGHT CREW :
Fri.,May 16 2008.
the brand spanking new Airbus 380-600 ,the largest passenger Airplane ever build ,sat in its hangar in Toulouse France ,without a single hour of air time.
Enter the Arab Flight crew of Abu Dhabi Aircraft Technology (ADAT) to conduct a pre delivery tests on the ground ,such as engine run ups,prior to Delivery.to Etihad airways in in Abu Dhabi.
The ADAT crew taxied the A380 to the run up area ,then they took all 4 Engine to take off power with a virtually empty Aircraft. not having read the run up manual ,they had no clue just how light an empty A380 really is.
the take off warning horn was blaring away in the ****pit because had all 4 engine at full power.the aircraft computers thought they where trying to take off but it had not being correctly confirmed (flaps/slats/ext).
then one of the ADAT crew decided to pull the circuit breaker on the Ground Proximity sensor to silence the alarm.
this full the aircraft into thinking its on the air.
the computers automatically released all the breaks and set the aircraft rocketing forward ,the ADAT crew had no idea that this is a safety feature so that pilots cant land with the breaks on .
not one member of the seven man Arab crew was smart enough to throttle back the engine from their max power setting ,so the 200 Million $ brand new A380crashed into a blast barrier totaling it .
the extent of injury's to the crew is unknown ,for there has being a news black out in the major media in France and elsewhere :
Coverage of the story was deemed insulting to Muslim Arabs.
finally , the photos are starting to leak out.
Google it :
Airbus 200 Million $ aircraft meets retaining wall and the well wins .
here's a link :
Airbus A340 Meets Wall. Airbus Loses. | Airline Empires
Moose.
Milwaukee.
Fri.,May 16 2008.
Google it :
here's a link :
Moose.
Milwaukee.
