Obviously I am not a mechanic - I still think it helps to beat on a battery with my shoe if the durn truck won't start! But, yesterday we got loaded and pulled over in the shade to wait for our departure. It was a HazMat load. When we finished with the details for departure our truck would not start! Grrrr! Beating on the batteries with my shoe would not work!
A mechanic came and worked on the truck. He found a problem with one of our fuel/water separators. He repaired it and we were on our way. But while he was diagnosing the problem he mentioned that in these new trucks (ours is a 2007 Freightliner) never, ever, under any circumstances let anyone spray ether into the air intake. This used to be a common fix to start a diesel engine. Here is the explanation I found about it: There is a big caution here however. Some engines have pre-combustion chambers and or glow-plugs. These and ether DON'T mix. So make sure it's correct procedure for your truck before using ether.
This mechanic said the ether would cause an ether lock on our engine and it could mean the engine had to be replaced!! He says if you ever see a mechanic heading to your truck with a can of ether tell him you do not want it! india
India Hamner
[font color="purple"] FEDEX [/font][font color="blue"]Custom Critical[/font]
D Unit
Wisdom is what's left after we've run out of personal opinions
India Hamner
D Unit
