paradisecustom
2008 258 ALP Hino. Was coming back from a tow job with my Hino rollback and the check engine light came on. Lost power and could only go 5 mph uphill and 35 mph on the straightaway. Came back to shop and checked the codes - P0088, P2101, P2103. I took the hose off between throttle body and air charge cooler. When I shut it off, the throttle plate was still open approximately 1/4 way from the throttle body. I sprayed carburetor cleaner on, replaced the hose. It seemed to be running fine. I took it to another tow last night 8 miles away and it drove perfectly until I started back. The check engine light came back on, lost power again. If this is the throttle body and I replace it, do I have to take it to dealer to program it?
