Kudos to the Enemy and Jenny
The other day Steady Eddie blew his belt tensioner and the Enemy aka Nick and Jenny turned around and went 70 miles out of their way back to assist Eddie.....Now that is just what kind of expeditors they are.....Thank you Nick and Jenny for being my friends!!:D
Steady Eddie
Well, since you let the cat outda the bag...... You know Nick and Jenny didn't do what they did for Kudos.
BUT.....
I sent Nick a PM to ask a question about changing out the part. He called a short time later and we talked a few. Hey, where are you? I told him and he said he can come back and give me a hand with it. They were at MM 60 on I55 in AR, I was in Mathews, Mo MM 58. I really didn't want them to turn around, but they did anyway.
I offered money "nope" I offered to fill up their van..."nope" well dang.....how about the next time we run into each other- FOOD! ok. Great!
Even though we didn't slove my problem due to a rounded bolt, it showed me how great these young folks are. You don't see that type of value in folks nowdays.
I don't understand why Nick's screen name is The Enemy, I doubt he is a Enemy to anyone!
Thanks Nick and Jenny!
Steady Eddie
Oh, and what’s the best way to get stories out?
Telephone
Telegraph
Tell a woman
Nope. It’s telling OVM!
:rolleyes:
chefdennis
I hadn't been on EO READING this morning when Nick and Jenny pulled into Laredo...i just heard the story...I totally agree with Eddis not understanding Nick's screen name..I really don't think anyone would think of Nick as the Enemy....
My hats off to both Nick & Jenny...
And you are right Eddie, I know Nick didn't do it for Kudo's...he is just a good guy....
purgoose10
Expediters of the year award. Nice to get help from all, but that is above and beyond the call.:D:D
aileron
Nice of him to do that. And I know why he did it. It does not matter the company, or anything else. He did it for the satisfaction of helping someone that is stranded on the road. I would have done it also, and I know there are a few others that would too.
By the way, I carry with me the basic parts for sprinters, and I also have a DAD sprinter diagnostic software to read sprinter specific codes of T1N sprinters (up to the year 2006). If anyone needs some help I might just be around.
Steady Eddie
I have a floor full of parts. I bought the kit from Euro parts, Just wish I had changed it out before it failed. That DAD you have, is that the one you can view or download onto laptop? Nice to have, I just have the Actron autoscanner, only good for read error codes and reset engine light.
aileron
Eddie,
I am not too familiar with your Actron scanner, but I guess it is a regular OBD-II scanner, which only reads the generic codes in all kinds of vehicles. DAD is a Mercedes specific tool that you can read codes in all computers in the sprinter (engine, transmission, abs, instrument cluster, gear shifter, etc). You can also see live data from these computers, like fuel rail pressure, data from individual wheel speed sensors, also you can shut off individual injectors to see which cylinder has problems, and many more. This thing does about 90% of what a dealer DRB-III does.
aileron
Oh, and yes, it is a computer program with a multiplexer that you connect between the OBD-II port and the computer.
Steady Eddie
I need to see that. I can read fuel PSI, and a few other things, and yes I can use it on any car or truck. Do have any info or link to what you have?
The DAD is very kewl. I have a Scangauge II which reads generic engine light codes, but the DAD will read all codes whether the codes throws an engine light or not, including old stored codes where a problem exists but doesn't result in an engine light, and will tell you how many times its been stored and under what conditions.
I recently replaced my transmission with one from Silverstar, and my mechanic nor the Chrysler dealer in town, had the Sprinter module software to reset the learned adaptives on the new transmission. The DAD reset them with one click of the mouse. It also gives you the transmission fluid temperature. The transmission fluid temperature was significantly different from the engine coolant temperature, and and knowing the transmission temperature is critical in determining the correct amount of fluid.You also need a technician's transmission dipstick tool, of course, and you can get those from the same place as the DAD.
Oddly enough, though, I can't get it to reset the ASSYST computer after an oil change, so I just do that the old fashioned way.
aileron
What happened to your tranny?
Did you drive it before resetting the adaptives? Was it shifting differently than after the reset? I wonder what would happen if I reset them now. Not going to try it probably.
She finally got sexual reassignment surgery and became something very different from before. yuk yuk awacka wacka :D
What happened was the same thing that happens to most of them in the 350-450 mile range - you start it up after getting fuel, or in my case after a nap at a service plaza, and it won't go in gear. A few off and restarts and it would work a little bit, like it was barely in gear, but when the RPMs got anywhere close to it having to shift into second, if would just drop into neutral and stay there, forward and reverse. I got it working enough to get me out of the service plaza and just about half way down the on ramp back onto the PA Turnpike, but that's as far as it would go. Turn it off and let it set for 5 minutes and it would go in gear, but was only good for about 40 feet. Forward or reverse.
Freightliner dealer in Harrisburg tried to give me a great deal on a new one, $6400 out the door. I ended up towing it home on a Uhaul dolly behind a 10-foot Uhaul box truck. The Sprinter is about 4 inches too wide, and 2000 pounds too heavy for those dollies, and of course that little box truck was really put to the test. It may very well need a new transmission at this point, too. :D It was pretty much all mountains from Harrisburg, through Maryland, down through West Virginia and Kentucky, and finally on down to home. About 850 miles of white knuckle fun.
The Silverstar transmission totaled $2800 including $200 shipping and installation labor.
No, I didn't try and drive it before resetting the adaptives. My mechanic was going to get the tool from the local Chrysler dealer to reset it, and they had the tool, but not the module for the Sprinters. My Sprinter dealer had the tool, but they're half an hour away and I'd have had to drive it up there to get it reset. DAD to the rescue.
It definitely shifted differently, because the computer didn't know squat after the reset. It had to relearn everything. It was really noisy at first, massive rumble-strip noise for the first few shifts, especially 2-3 and 3-4, but that went away quickly, and pretty much disappeared after a couple of days.
The initial test drive after the reset wasn't exactly the ideal test drive, wrong type of road and too much traffic. But it seemed to work. The next day, a Saturday, I took it out to a nice divided four-lane with wide shoulders and very little traffic, and reset the adaptives again and then did a proper test drive to have it learn to shift at the correct RPMs, as well as do the recommended five coast-to-stops where it would downshift properly and learn all that. Been running fine ever since.
You could certainly reset the adaptives, and you might want to if it's been shifting kinda goofy for a long time (years), but there's really no reason to reset it other than if it was badly learned in the first place and never really adapted.
