After noticing a vibration out of my front end, I had the truck put on a chassis machine. What they found was my king pins were wearing out, after 320,000 miles (Probably from too many trips to Detroit):7 Anyway, what I found out was that most trucks when coming from the factory new, use neoprene rubber bushings that wear out. My Kenworth dealer advised that when replaced, make sure you are getting brass bushings. He said some dealers will cut corners and use the rubber bushing. Not much difference in cost. (50.00)
The brass will last 3 to 4 times longer than the rubber ones.
Just thought I would pass this along. Something I wasn't aware of.
