I guessing they haven't Fixed the Loose Nut .. yet
All aboard the Freight Train
There's a bunch of nuts in Ford.I guessing they haven't Fixed the Loose Nut .. yet
He's probably having a senior moment - forgot his password to EO.Day two: The search for Rags
A day without Rags is like a day without sunshine.
Rags, if you laid big on the Vikings pm me.
You don’t need to hide.
You , Me, and Vinnie can have a sit down. We can work it out.
Whatever you do, don't drop the soap.Oops .
Rags surfaced while I was in the shower.
Not in my shower, although he’s welcome again.
In GEO’s thread.
In GEO’s thread.
I wasn't even trying 9 months before my daughter was born...You’re trying to get Rags out of Geo’s thread, aren’t you ?
Yaya, we found him. Hope you get better....Im here.... just feeling a bit under the weather..... sleeping alot.
Yummo.....Tell Ragmama to get the chicken noodle soup brewing.....
They all say that.I wasn't even trying 9 months before my daughter was born...You’re trying to get Rags out of Geo’s thread, aren’t you ?
My wife said, "just do it". Hence, the fruit of the labor.They all say that.
Here's all I know. Truck running fine. Went to Valvoline that AM and had oil changed. Drove away, went to Publix for grub, came back out, turned the key, crickets! My thought is the highly trained (minimum wage) oil change tech knocked a wire loose getting filter off???Do you know which wire ?
Was it related to engine swap ?
Feeling much better this fine friday morning.... still a bit tired, but the slight fever i had been running finally broke.Im here.... just feeling a bit under the weather..... sleeping alot.
And that's why you do it yourself, or be with oil mechanic to make sure he doesn't do it.Here's all I know. Truck running fine. Went to Valvoline that AM and had oil changed. Drove away, went to Publix for grub, came back out, turned the key, crickets! My thought is the highly trained (minimum wage) oil change tech knocked a wire loose getting filter off???
