dhalltoyo
Inverter:
Usage is limited to the battery capacity.
May cause interference with electronic devices.
Easy to use.
Expense to install?
Cost to replace batteries?
Generator:
Portables require refueling; hence, a fuel container too.
Not the easiest to use.
Usage only limited by fuel consumption.
Could also be used around the house or in other applications.
Initial cost seems to be around $1000-1800 for one that could power a microwave or a small A/C unit. It is rated at 3000 watts
Note: Rather than spending $3000 for an Espar, Inverter and batteries, I was considering a generator and an electrical heating unit. I could cut the heater long enough to use the microwave and then resume heating the van. The area to be heated would be approximately 7' x 8' x 8'.
Easy to use.
Expense to install?
Generator:
