Don't forget that many auto parts skids are substantially bigger.A standard pallet is 48"long by 40" wide.
Keep in mind, nothing is 'normal" in expediting...
No truer words were ever typed!
Personally,I put 13 ft of e track in figuring 12 ft for cargo and 6 inchs on each end for freight bars and or straps to secure frieght....
and yes most automotive "bins" are 48x45, alot are 48x48 and more then a few of the "steel bucket bins" are 48x52....
My 2nd load in my new van that has a 14 ft load floor was a "Speciality Automotive Rack" that was 13.5 ft long...
My "sleeper area" is 6 ft long, but it can quickly be converted back to a 13 ft load floor....
I think your question is, "How do you guys get "TO" the load "IN" the front end ,,,,of the cargo...
Ok, to get a skid up ft, the highlo driver uses the last skid to be loaded to push the 1st one loaded to the ft..then to unload the FRONT skid, there are several ways...I personally have a 12 ft long chain with a automotive tow truck hook on it and a small hook on the other end to hook onto the higlo rack so they can then pull the skid back to the end of the van..
There are also "pallet-pullers' available that you use with a chain. Then there is always a loang nylon strap that can be used...
Thanks chefdennis. Now, what if you have one 3000 lb skid and a 158'' long cargo and you want to get that skid passed rear axle of the van so you don't have all this weight right on the axle and they are not able to push it that far. I may be asking stupid questions, but I am still new in this type of business.
Make sure to have e-track, 2 rows, on the floor, the whole 12 ft, to be able to properly secure the freight..
You should have a plywood deck put down (screwed or bolted) on top of the factory deck. A lot of people just use the factory deck, but if the plywood gets chewed up it is a lot easier to replace.I do not have the e-track, and I would like to get it installed. I would greatly appreciate if anybody know the do it yourself steps or should I get them installed by a professional ? And where do you buy this two 12 ft rows from. I hate to see my Sprinter floor scratching every time I get loaded/unloaded.
