P51bombay
On the to do list for this weekend is installing:
Dynamat on the floor, ceiling, walls and doors
Routing CB cable & install antennas- (truck didn't come with one)
Replace spot mirrors with heated ones
Install new Seats, inc seat.
Install new midship signals
For anyone contemplating such a job a couple pieces of advice: First get a trim panel tool - I didn't as I only saw the two large ones in the middle of the headliner and figured I'd just replace those but there are also I series of wire clip type ones up near the top edge of the windshield that aren't so easy to remove. The other thing is a second pair of hands would be VERY helpful in removing/installing the accelerator pedal since KW used nuts/bolts rather than putting a nutplate in the floor - god only knows why they did that.
Getting to this point in the photos is about 4 hours work, so this would NOT be a cheap job to have done although a shop that's done it before could probably do it in half what it took me. Other than the interior panels, sound insulation consists of a single layer of quarter inch open cell foam - its no wonder so much engine noise passes though the cab.
In the morning I can start cleaning up (there's quite a lot of dirt that gets under stuff) and installing some Dynamat before moving on to the other stuff.
More to come..........
