aoexpress1
I understand what hot shot flats are, but what I are hot shot trucks? Are the our expediter trucks? straight, cargo van, etc.
Definition
A hot-shot truck is typically a diesel-powered, dual-wheeled pickup truck that is set up to haul a gooseneck trailer. Hot-shot trucks are commercial for-hire motor carriers that transport freight from shippers to receivers. Hot-shot truckers can be independent owner-operators or they may be leased onto a larger trucking company.
Weight Limit
Hot-shot trucks are normally limited to a gross weight of 36,000 pounds.
Operating Range
Hot-shot trucks can travel anywhere normal-sized semitrailers can travel with the appropriate licensing and operating authority. Hot-shot trucks are governed by the Federal Motor Carrier Safety Administration.
Types of Cargo
Hot-shot trucks carry all types of freight that don't require the use of a full-sized tractor-trailer. In some cases, they transport specialty freight which can be hauled on the smaller gooseneck trailers.
Income
Trucking rates are determined according to freight classification, which is set per National Motor Freight Classification (NMFC). The NMFC determines freight class based on the size, value and difficulty of the freight to be transported. If an owner-operator is leased onto a larger company, there is typically a 25/75 split on the freight charges, with the company retaining 25 percent for booking the load and additional paperwork.
Sorry. I am applying for a carrier position with a company, there is no option for straight trucks. You have 48' van, 53' van, flat bed, step down, hot shot vans, hot shot flats. Those are the options. Not sure if my straight truck fits into the category of hot shot vans.
