Hino rear main seal
zackcts
Birthday Expediter
It's My Birthday!!!
hi guys have a 2008 hino fg engine has been pulled out as rear main seal is gone wanted to take bellhousing of to replace the seal properly and remove it but the head is bolted to top of housing and dont really want to remove it just for the 2 bolts
is their any other way to replace this seal with out removing bell housing and head cheers
There's a factory tool for replacing the rear main seal, and using it is the only way to ensure that it gets installed at the correct depth.
You should be able to remove those bolts to remove the bellhousing.
Reactions: Hino123
