GVWR / GCWR Rating
streetsweeper
Frank;
Do you know anything about states registering a unit going by the manufacturer's axle weight rating instead of gross weight? I was told this and I'm pretty confused about it.
I do know with class 8 units, legal limits are 12,000 ft, 34,000 tandem axles rears tractor & trailer for a combined weight of 80,000lbs.....but a class B unit & trailer?
Am I being fed a line of bull?
Fkatz
Hi streetsweeper,
I have no idea of what or why they are rating the Cargo Van, by axle weight, A "b"unit is a standard vehicle similar to a pick up of 1 ton capacity, I think that some one is pulling your leg, plus you cannot put a more than a 8-1 ft trailer on it because it will not be able to carry the load
Frank
streetsweeper
Hey Frank, thanks again.
I fubar'd that, the question should have read 'have you heard anything about states taxing a vehicle by the Gross Axle Weight Rating' (GWAR- The manufacturers maximum Gross Axle Weight Rating vs GVWR).
Thanks!
streetsweeper
Frank;
Sory, I fubar'd the question. It should have read Gross Axle Weight Rating vs Gross Vehicle Weight Rating for licensing one ton pickups & up.
Thanks again!
Fkatz
STREETSWEEPER,
I REALLY DO NOT KNOW THE EXACT ANSWER TO THAT QUESTION YOU WOULDHAVE TO GO TO YOUR STATES DOT REGULATIONS TO FIND OUT OR YOUR LOCAL DMV OFFICE
FRANK
