GPS interruption
There is going to be a partial interruption of the GPS system in the Southeast U.S. between Jan 20th and Feb 22. A similar interruption took place on Jan 10th in the Northeast, in the MD/DL area. I was lucky enough to see that one. Watched my GPS receiver lose signal for around 20 minutes.
These short interruptions should have little effect on us. This is a warning from the FAA.
FAA warns of ongoing GPS issues in southeastern US due to Defense Department 'tests'​
Don't panic, but anyone planning on using GPS in the southeastern US for the next month or so will likely want to make sure they have a fallback option. That's according to a flight advisory just issued by the FAA, which warns pilots that their GPS signal "may be unreliable or unavailable" due to "GPS tests" that the Department of Defense will be conducting between January 20th and February 22nd. Details are fairly light beyond that, but the FAA does note that when the "tests" occur they will be active for 45 minutes, and be followed by 15 minutes of off time -- additional notices to pilots will apparently be issued at least 24 hours prior to any test. Of course, while this particular advisory is directed at pilots, it will presumably will also affect all other GPS devices, as the FAA doesn't mention any GPS issues specific to aviation. The real question, however, is just what those mysterious "GPS tests" are -- if they're, in fact, GPS tests at all...
FAA warns of ongoing GPS issues in southeastern US due to Defense Department 'tests' -- Engadget
https://www.faasafety.gov/files/notices/2011/Jan/GPS_Flight_Advisory_CSFTL11-01_Rel.pdf
Well Someone already posted this.
But if you are that dependent on the GPS system, you shouldn't be driving.
Imagine how many soccer moms are going to be lost when it happens?
I did not see that other post until after I posted.
I am not dependent on the system but many are. Can you imagine the "mess" if they "interrupted" the system over the Great Lakes? LOL!! There would be "GPS RANGERS" running a ground all over Lake Erie!! How funny would that be? :p
