astikhossw
A mech. told me the other day that engines with dpf,when changing the fuel filter should not have the fuel filter filled with diesel and then installed,it should be installed empty and then primed using secondary filter priming valve.He told me that when a place like speedco or T/A change there filters the diesel that they use has to many contaminants and the filter only strain out the larger microns and not the smaller ones due to them pouring the fuel directly into the filter so what happens is the smaller particles end up in the ejectors causing them to become semi clogged.Has anyone heard of this before and are you having yor fuel filter changed like this.
