finding balance point when stretching a class 8
I am looking fairly seriously at getting into a class 8. I haven't decided if I will go new or slightly used. I've seen several Volvo's and T600's with less than or barely over 100,000 miles on them. If I go that route I will have to have the frame stretched. Is there a formula for determining the wheel position? I thought about the centerpoint between the rear axles below the centerpoint of the box but didn't know if that would work out or not.
I'm also still considering a truck like the one on www.sst100.com and later adding a tag axle but I think I'd rather have the tandems. I think it would be more stable and also a more comfortable ride. I know Toes has experience in this and hopefully will add his input and I appreciate any and all comments.
Leo
truck 4958
tazman
RE: finding balance point when stretching a class
If you provide some specifics ( like GVWR , WB , CA and GAWR ) I may be able to run the configuration through the calculator program I have access to ....
This will give you the new CA and BL (body length).....
Generally 60% to 70% of the body should be forward of the center of the rear axles...(rule of thumb)....
Hope this helps...
Frank in Pa.
"The Beast in the East":)
A Plus Expediting
A Plus Expediting
(937) 424-0220
Advertiser
OTR SPRINTER VAN OWNER OPERATOR
Are you looking to put your superior driving skills to good use? Do you have an extensive track record of clean and safe operation, timely delivery, and dependability? If so, then this driver’s position could be perfect for you. Successful drivers communicate clearly with dispatch, deliver product on time and safely, and can perform these roles w ... Apply Today!
>If you provide some specifics ( like GVWR , WB , CA and GAWR)
>Frank in Pa.
Well, here's a chance to look dumb but I don't know what CA is. I'm looking at either a Volvo 780, KW T600, or KW T800, any of which would be 52k GVWR. Whichever I choose would have 12,000 front and dual 20,000 rear axles which I presume is GAWR although I may learn I know less than I think I do. The CA part I'll have to not guesstimate until I learn what that is and the wheelbase is the variable I'm trying to figure out to know how long to tell them to make it once I choose a platform. Thanks for any hints you can provide.
Leo
truck 4958
tazman
CA means Cab to Axle length
CE means Cab to End of frame...
Most trucks use a CA to determine the load balance...and the body length.....
Hope this helps
Frank
If/when I find a truck that I'm serious about I'll get and post actual numbers.
Leo
truck 4958
jaminjim
But are you limited to 34k on twin screws?
It would be a 52k gvw truck. The limiting factor would be box length I believe except perhaps in rare circumstances.
Leo
truck 4958
A Plus Expediting
A Plus Expediting
(937) 424-0220
Advertiser
