Since I can't post in the FedEx forum I will post my thoughts here. Being with FedEx Custom Critical for almost 14 years I can say that DVA is a really good system if you understand how it works. DVA is based on 20 different things that makes the choice on what truck gets offered the load. Dwell time is just one of them. I will say that I wasn't sold on it when Jack Packard rolled it out in 1998. After I took the time to go to the home office and sat with the agents, I understood how it worked. If you stay within 25 miles of the Express Centers you find out that DVA will work for you.
Remember it was set up based on being 25 miles or closer to the Express Center. If your more than 25 miles from the Express Center it does take away points for that. Also DVA was setup for the 90 minute pickup. The 1st year they went to DVA I made more money for all miles then the year before. I went from making $1.13 for all miles in a C unit to making $1.31 for all miles in a C unit. It's a great system and you have to go to Green to see how it works. The system will not let you get pasted over on a load without a window popping up for the agent to explain why they are skipping you, and they better have a good reason if they don't want to lose their job.
For those who get upset about DVA. You should stop by the home office and ask to sit with dispatch and you will understand things better and how it works.
