Eyesight , check this out. It works , have fun.
Check your eyesight, this really works. Found it on a health site.
[YEA] 11/07/2009: Martha E. Martinez from El Centro, Ca writes: "This is amazing. The way to improve (I'm afraid to say completely cure) your eyesight is to do this: Peer thru a small hole the size of pencil lead width. Use a card or your hand. Look thru and you will see your eyesight is perfect! Not sure exactly why it works but if you use it to exercise your eye, it will improve your eyesight dramatically. You can even feel your lense contract as it works to adjust itself. It works quickly and 5 minutes a day for a couple of weeks will do the trick. Then just as needed after that to keep them eyeballs in shape! And if you ever forget your glasses,peering thru a pinhole will do in a pinch.
They sell what are called pinhole glasses online.
:D:D:D
AMonger
I call Bravo Sierra.
You know the problem with bad cops? They make the other 5% look bad.
It works the same way as stopping down the aperture in a camera lens. You can do the same thing by curling your pointer finger down to your palm and making a tiny circle to peer through. The smaller the aperture the greater the depth of field. It won't be as good as proper corrective lenses but will help. The failure of course is the tiny reticle which would be unsafe for things other than sitting reading or watching tv.
