Do you have rear air/heat?
Found this under my van; anyone know what it is? I wonder if it's a piece of emissions equipment.
2009 Ford E250, 4.6 engine. Item is in the spare tire area.
Sent from my XT1028 using EO Forums mobile app
It may be a rear axle cooler which means it could have been set up to haul as a ambulance.
Look for residue....
Here's a guy that shouldn't be doing any of his own maintenance! Lmao
Question: Where are the brakes for my 1987 Ford Econoline 150 van located?
Answer: At the wheels behind the tires
I just choked on my breakfast laughing.....lol...
you'll find that is part of the evap purge system on your gas tank it recycles the creates a vacuum in the fuel system and burns excess vapor in the motor
also known as a charcoal canister in the olden days should also contain an evap purge valve!
