Broompilot
Being a little bit of an expert on this.
The Cummins ISC has a poorly designed exhaust manifold that it is one piece. Brand new this truck got a crack and almost killed me in my forth month of service when the APU had failed and I idled the truck to keep warm. Heacache, upset stomach WOW I was very sick. No noise just the killer gas and I could smell it after I woke up.
This was late March, no realizing I had a leak I just thought it was from idleing it and being a rookie did not have the info to know what was going on. The summer months kept the engine metal from contracting and expanding as much. Come November it was fumes + noise. Repaired under warranty.
Now one year forward, the injectors failed and with trying everything under the sun to figure out why a Dyno was performed. The stress caused the mishap to happen again. This time you'd a thought I was riding a harley with straight pipes and the gas appeared again. My dealer wanted me OUT OF THERE after over two weeks they were more eager for me to get back to work than I was. But after getting the trucks injectors all set and returned from Cummins with now another broken exhaust manifold and no parts for at least another day.
My dealers Service Manager called me into a short meeting and explained "I cannot stop you but I do not want you taking this truck until we fix this". After my earlier expierence my life was just little more important than the next run I would miss. They did give me a giant break on replacing the manifold, and I figure this will probably be an on going repair for this engine. So it goes.
The problem being compared to Cats, is this a one piece manifold with all that heat and expanding and contracting its gona crack plain and simple. Cats are designed in smaller pieces so not as much of the stress on a large piece of metal but either three or six different mini manifolds leading into the exhaust pipe.
If you have a Cummins ISC and you hear anything odd from the engine especially during acceleration HAVE IT CHECKED.. The repair should be around $700 and maybee less at a local shop.
I wonder how rich my wife would be if I would not have woken up that Saturday in Seattle? She is stuck with me now.
