Espar heater and APU's
Does anyone have both the Espar heater and an APU on their truck? I got to thinking about it and the Espar is supposed to use only about half as much fuel as an APU uses, if not even less than that. You also reduce pm expenses on the APU as well as extending the useful lifespan. That got me wondering if it might not pay off over a couple years time to have both so you could reserve the APU for battery charging and air conditioning.
Owner, Panther trucks 5507, 5508, 5509
EO Forum Moderator
Broompilot
Leo I am at a loss as the comment regarding the cost of maintenance. An oil change a Speedco is under $20.00 I probably spend less than $300 annunally on the PMs and belts. I just do not find this to be excessive and I service mine more than I should cause of the low cost at Speedco.
Bolt Express
Bolt Express
(800) 545-4789
Advertiser
Class A CDL Regional Owner Operator
Class A CDL Regional Owner Operator OpportunitiesBusiness is GREAT, consistent FREIGHT in the lower 48! Average Gross Revenue to the vehicle monthly                      Midwest out to all pointsFlexible DispatchPassenger policy CALL our Professional Recruiting Team at 866-974-4984 or visit www.bolt-express.com ... Apply Today!
cornerstone
My understanding of the ThermoKing Tri-pac is that it is an apu and uses a seperate heater. In the winter you run your heater without the apu turned on and when the voltage gets to low the generator turns on to charge the batteries. This seems like the best setup but it does come at a higher price. I have heard over $9K. I wonder how long it would take to justify that cost.
Cornerstone
It's similar to fueling in Florida or Georgia. It isn't large amounts of money but it's enough to notice and add up over time. With a 400 hour service interval and a minimum of 10 hours daily APU operation during required DOT breaks that's a service every 40 days out. Add in the times where you sit over the weekend or have a less than 14 hour day and you could reach 400 hours APU run time in a month. When you're up north and it's below freezing 24/7 you have to have heat running 24/7. If the APU is 4 hrs/gal and the Espar is 12 hrs/gal then it's 6 gallons fuel for the APU or 2 gallons for the Espar. The APU pm goes from 30 days to maybe 75 days. Theoretically that's a savings of 300 gallons fuel and 1 pm in 75 days. Maybe it isn't worth it but it's something that crossed my mind and I thought I'd see if anyone had tried it.
EO Forum Moderator
Paul56
>truck?
We have both a ProHeat and an Espar, but not for the reasons you suggest below.
We want the redundancy in case of failure since we often run in very cold remote regions where a failure could mean major trouble.
The air conditioning is great but something of a luxury as compared to the need for heat.
>you suggest below.
>trouble.
What is the approximate run time of your Espar on one gallon of fuel?
EO Forum Moderator
Paul56
Well, these are estimates: Proheat consumption 2.5 litres/hour, Espar at 2.0 litres/hour. The Espar unit is one of the larger ones rated at ~60,000 BTU. Conversion for you sensible folks State-side who haven’t gone metric: 0.66 gallon/hour and 0.53 gallon/hour respectively.
When calculating operating costs we round up and calculate at 1 gallon/hour consumption rate for both. The difference really doesn’t amount to a pile of beans either way, in any case I’d rather estimate a little higher than lower.
Bolt Express
Bolt Express
(800) 545-4789
Advertiser
