My engine fan has decided that it should turn it self on anytime I turn on the AC or defroster. It makes no difference what the outside air or engine temps are. It will continue to run for as long as 45 minutes after I shut off the air. I thought it might be the pressure switches/sensors on the AC. I had them checked, both the high pressure and low pressure sides are giving correct readings. I have a 2005 MBE900 450HP. I have been told that it could be a problem with a EGR sensor or some other sensor that I cannot remember the name of. Has anyone else had this problem? If so, what was it? I also found out today that the engine has a recall/modification on it for a freeze plug problem. Do people check on recalls every so often on your own or is it Freightliners job to inform you of these things. I checked 6 months ago and the was no outstanding recalls, or at least that is what I was told. Layoutshooter
