Just to let everyone know that if your EGR unit goes bad have the shop change the oil and clean out your trucks oil system. If your trucks EGR unit leaks it can put coolant in your oil. How that comes to happen is once the truck is turned off the coolant can leak back into the oil. Once that happens your oil filter will be all messed up and will not let oil flow. Then your motor is junk. It cost us $14440.00 to get a new crate motor and to have them put it in our 2005 M2. My brother in law got us a deal on the motor. It took over 9 months to settle with the dealer that put the EGR unit in the truck. Freightliner of Knoxville wanted $21,000.00 to put a new motor in a truck that wasn't even two years old at the time.
Just a little FYI, everytime you get your oil changed have them check your oil to see how it breaks down. If you do that then you will not run into the things we did. Our Truck sat for almost two months before I had it towed to Akron to have a new motor put in at R and R engine. Three months of downtime on this truck cost us over $50,000.00. So now we have the oil checked everytime at Speedco. Paying $7.50 to do that is a lot cheaper than $14440.00 for a motor.
Drive safe
Dave Mayfield
FedEx Custom Critical
14 years as an O/O in Expediting.
Drive safe
Dave Mayfield
