bikerpaul
What is the difference between a vehicle designed for E85 and a non-E85 vehicle? My 2008 Ford 406 liter E250 has the gas cap that says to not use E85, but also in the owners manual it lead one to believe that some were made to use it. I have found E85 conversion kits on the internet, and from what it says, you hook up the conversion box between the plugs that goes onto the fuel injectors and the fuel injectors, and hook up a ground wire. There is nothing changed in the engine. If this is the case, what would happen if E85 was used without the conversion kit?
