How often do you other Droid users have to do a battery pull to fix an issue? I seem to be at about once a month to take care of connecting to my bluetooth or getting my e-mail.
Adobe sends updates? Huh? How? Are they pushing updates? Do you have Adobe apps flagged to automatically update? I've never received an Adobe update other than the ones I go to the Marketplace and download, and I run both Flash and Reader.Mine will freeze up when Adobe sends an update. No choice but to pull the battery then.
Battery pulls should only be done if the phone freezes up. It won't hurt the phone or the battery to do lots of pulls, but it's really unnecessary unless the phone stops responding. I too have a Seidio case, and a thick, extended battery (original Droid), and doing a battery pull is a bit of a PITA with the Seidio case, 'cause you gotta remove the case. I've only had to do a battery pull maybe half a dozen times.
The phone is a computer first and foremost, and like most of 'em you need to reboot them once in a while. I reboot mine probably a couple of times a week, tho I should probably do it more often. It just clears the CPU's head and gets things back operating more efficiently. It should be a hard boot,meaning shut it down, then start it back up. There are a lot of phones with a certain version of the OS where you push and hold the power button and select "Power Off" and instead of powering off it shuts down and does an immediate soft reboot. If that happens, wait until it gets to the stage where it mounts the SD card, then hold down the power button again and this time it should go ahead and power down for real. Then hold the button down for 3 or 4 seconds to initiate a boot.
I'm also pulling my battery every couple of days but only since the 2.3.3 update and it seems to be a conflict with the launcher I'm using.
OK, thanks for that clarification. I have a few apps set to auto-update, but not many. Have to be careful about that.
