dieseldoctor
My Dream Van is nearing completion so I thought I would post some pictures and description of it so other drivers could maybe get some ideas they can use on their van or other trucks for that matter. Also I welcome any ideas or suggestions anyone has on how to improve on my ideas. The van is a 2004 Ford E-350 with an Unicell SRW body. It has a 5.4 v8 gas engine and 4.10 rear axle ratio. For the second quarter which is the only full quarter I have ran it we put 34,693 miles on it and averaged 14.3 MPG. It has 2" of sprayed in foam insulation in walls, roof and under the floor. As you can see from one picture I installed an TurboMax vent fan on top. This fan has three speeds, can pull air in or pull air out and has a thermostat. With vent shades on the windows I can leave them down a little and run the TurboMax even when it is raining hard with no problem. It works good when it is not too hot. I use it at home also to keep the temp inside the van from getting so hot inside. Without it the inside temp gets over 105 degrees but with it it stays in the 90's. One picture is of the inside of the van with the bed raised all the way to the top. In this position I can clear a load about 55" high Will show the bed in the down position later. Bed can be used anywhere from all the way up to about 18" off floor. Another picture shows the back of the van and shows what I call a forklift bumper. This fits into my trailer hitch receiver and keeps the forklifts off my regular bumper. As you can see it has three lights in it and they burn anytime the engine is running and the parking brake is released. I also have a button on the turn signal lever that I can use to flash them to thank drivers that signal me it's safe to pull in front of them.
If you see anything in the pictures you have a question about I will be glad to answer it if I can. Will start inside the van on the next post. Dieseldoctor
