Cures and comforts
louixo
I like these home remedies, because they usually work. Of course they don`t work for everybody, but if you have the problem it`s worth a try. these cures use everyday products you find around the house.
Eliminate ear mites. All it takes is a few drops of Wesson Corn Oil in your cat's ear... massage it in, then clean with a cotton ball. Repeat daily for 3 days. The oil soothes the cat's skin, smothers the mites, and accelerates healing.
Kills fleas instantly...Dawn Dishwashing Liquid does the trick. Add a few drops to your dog's bath and shampoo the animal thoroughly. Rinse well to avoid skin irritations. Good-bye fleas.
Rainy day cure for dog odor: Next time your dog comes in from the rain, simply wipe down the animal with Bounce or any dryer sheet, instantly making your dog smell springtime fresh.
Did you know that drinking two glasses of Gatorade can relieve headache pain almost immediately-without the unpleasant side effects caused by traditional pain relievers?
Did you know that Colgate Toothpaste makes an excellent salve for burns?
Before you head to the drugstore for a high-priced inhaler filled with mysterious chemicals, try chewing on a couple of curiously strong Altoids peppermints. They'll clear up your stuffed nose.
Achy muscles from a bout of the flu? Mix 1 tablespoon horseradish in 1 cup of olive oil. Let the mixture sit for 30 minutes, then apply it as a massage oil for instant relief for aching muscles.
Sore throat? Just mix ¼ cup of vinegar with ¼ cup of honey and take 1 tablespoon six times a day. The vinegar kills the bacteria.
Cure urinary tract infections with Alka-Seltzer. Just dissolve two tablets in a glass of water and drink it at the onset of the symptoms. Alka-Seltzer begins eliminating urinary tract infections almost instantly-even though the product was never been advertised for this use.
Honey remedy for skin blemishes... cover the blemish with a dab of honey and place a Band-Aid over it. Honey kills the bacteria, keeps the skin sterile, and speeds healing. Works overnight.
Listerine therapy for toenail fungus: Get rid of unsightly toenail fungus by soaking your toes in Listerine Mouthwash. The powerful antiseptic leaves your toenails looking healthy again.
Easy eyeglass protection... to prevent the screws in eyeglasses from loosening, apply a small drop of Maybelline Crystal Clear Nail Polish to the threads of the screws before tightening them.
Cleaning liquid that doubles as bug killer... if menacing bees, wasps, hornets, or yellow jackets get in your home and you can't find the insecticide, try a spray of Formula 409. Insects drop to the ground instantly.
Smart splinter remover: Just pour a drop of Elmer's Glue-All over the splinter, let dry, and peel the dried glue off the skin. The splinter sticks to the dried glue.
Hunt's Tomato Paste boil cure... cover the boil with Hunt's Tomato Paste as a compress. The acids from the tomatoes soothe the pain and bring the boil to a head.
Balm for broken blisters... to disinfect a broken blister, dab on a few drops of Listerine,a powerful antiseptic.
Vinegar to heal bruises... soak a cotton ball in white vinegar and apply it to the bruise for 1 hour. The vinegar reduces the blueness and speeds up the healing process.
Quaker Oats for fast pain relief... it's not f or breakfast any more! Mix 2 cups of Quaker Oats and 1 cup of water in a bowl and warm in the microwave for 1 minute, cool slightly, and apply the mixture to your hands for soothing relief from arthritis pain.
EagleRiverWI
A couple of years ago, That famous medical expert, Madonna, recommended peeing in the shower to cure athletes foot. Maybe she should try truck stop showers.
are12
Best cure for poison ivy: Baking soda - using water, make it into a paste, apply to affected area and leave it dry. You will see a great improvement after one use. The only thing is, it can be a little messy. I suggest putting a towel or sheet down where you will be sitting - since it does flake off once it is dried. :p:p
Penguin
Baking soda paste also works for sunburn. It burns even more when you first put it on, but eases of quickly.
If you have a really tight chest and are coughing and hacking, just before going to bed take the usual Vicks Vapo-rub, and apply a good coating TO THE BOTTOM OF YOUR FEET. Put on a pair of socks, and by morning you will be much better. Sounds crazy, but it works!
Suds43
Has to be 'white' vinegar for sunburns............put on with a cotton ball before going to bed, wake up in the morning with no more sunburn pain and it's a nice golden tan.
