I know some drivers out there that use a pager instead of the company computers that they give you at 100.00 a month rental. A pager cost 50.00 a month with nation wide coverage. plus when you
check in to a city or express center you can check 100 miles out instead of 25 miles zone. this way you will check in soon then other
trucks and get a load faster. Another way is to use both personal
pager and computer but put a cut off switch on the computer so when you check out of a city after 6pm. you still show in that city but
you are moving .The company can still get a hold of you on your pager.
The bonus of this is most loads after 6 pm . pick up the following
morning or very late that night.You can still check load status in that city .A good example of this is detroit or chicago you can move
from area to another being in both at once!YOU MUST USE A CUT OFF
SWITCH ON THE COMPUTER TO SEE THE PLUSES. In the winter you don't have
to run your truck or van thus saving gas!!!
good luck
good luck
