TSexpediter
I have same problem on two expess vans. 4.8 l gas engine. Sudenly the oil pressurre running low. Both engine are 400 kmiles. They no burning oil no smoke. Should I change the oil pump, replace the engine or should I run with low pressure untill the engine is completly done? Idle 8 psi , when running on the hwy 20. Did somebody have the same problem? Thank you
