charging batteries, a finer detail
ebsprintin
Okay, I just installed a set of auxiliary batteries in my sprinter. I now have the ability to finely tune the voltage levels of charging. If the battery manufacturer gives me a voltage range for bulk and float, do I shoot for the middle of the range or does it make a difference if I go higher or lower within the ranges that they recommend?
eb
piper1
I know Turtle will chime in with the correct info but, with my charger, bulk is the voltage it uses when it is taking the batteries back up to 90% then it goes into absorption/float to gently put in the last bit and hold it steady. I believe mine is 14.5 bulk and then 14.3 float (on the AGM battery type setting). I dunno if you can just set one voltage? What type of batteries did you put in eb?
Bolt Express
Bolt Express
(800) 545-4789
Advertiser
Class A CDL Regional Owner Operator
Class A CDL Regional Owner Operator OpportunitiesBusiness is GREAT, consistent FREIGHT in the lower 48! Average Gross Revenue to the vehicle monthly                      Midwest out to all pointsFlexible DispatchPassenger policy CALL our Professional Recruiting Team at 866-974-4984 or visit www.bolt-express.com ... Apply Today!
ebsprintin
I'm using two Lifeline GPL-6CT batteries in series. They are the tallish dimensioned, 96 lbs, six volt batteries for 300 amp-hrs of storage. I'm using two Xantrex dc controllers for the time being. One along with a battery temperature sensor controls charging and the other controls the load (low voltage disconnect). My goal is to keep everything in my system direct current, so to avoid having to use an inverter.
The batteries call for 14.2-14.4 volts for bulk stage and, I think (my manual is out in the van), 13.2-13.4 volts for the float stage. My controller allows me to precisely set the setpoints to the 0.1 volts, which is what led to my less than clear question--set controller to 14.3 and 13.3 volts for bulk and float ranges, respectively, or is there a reason to go higher or lower within the acceptable ranges? It might be more a theoretical concern at this point, but every bit of potential is sweet when trying to balance weight, dollars, freight and comfort, and the life of these expensive components.
eb
The charging parameters of AGM batteries are critical to the life of the batteries. 14.2-14.4 for the bulk/absorption stages, and then 13.2-13.4 for the float.
Three Stage Charging is different for regular lead acis batteries and AGM batteries, but for AGM batteries, in the Bulk Stage current (amps) is sent to batteries at the maximum safe rate they will accept until voltage rises to a pre-set limit, in this case 14.2-14.4 volts, which is near (80-90%) full charge. With Lifelines, the max current is up to 500% of the battery's amp hour rating, so they'll take anything you can give them.
In the Absorption Stage, the batteries are continues to be charged at the constant voltage rate of 14.2-14.4 until the current drops to less than 0.5% of the battery's amp hour capacity (.5 amps for a 100AH battery, or 1.5 amps for a 300 AH battery). At that point the battery is fully charged.
The Float Stage (also known as trickle charge, or maintenance charge) is where the voltage is reduced to a level that minimizes overcharge while maintaining the battery at a 100% state of charge. For AGM's, that's 13.2-13.4. More than that and you're overcharging, less than that and the batteries will not maintain a full charge.
These numbers are for 77° F (25° C) and the voltages will have to go up or down depending on temperature. Temperature compensated charging is crucial to the proper charging of the batteries. At 90° F, instead of 14.2-14.4 volts, you need 14.05-14.25 volts for the Absorption, and 13.03-13.23 volts for the Float. If you set the voltage to 14.2-14.4 and the charge controller will automatically compensate for the monitored temperature, you're good to go.
The other critical component to proper care and long life is the Depth of Discharge (DoD), which should be as little as possible, but not more than 50% on a routine basis. So, for a 300 amp hour battery bank, never discharge more than 150 amps without fully recharging them. Far as I know, the Xantrex Charge Controllers will only remain at the Absorption Stage for 1 hour, and then will move to the Float Stage, and how long it stays at the Bulk Stage depends on the internal voltage of the batteries. These controllers are designed for PV applications and can sometimes be a problem when charging from an alternator (if that's how you have it hooked up). So it's something to keep an eye on. Also, make sure the Low Voltage Disconnect is set to somewhere around the 12.0-12.2 volt range. If you let it get down below 12.0 volts, you are well under the 50% DoD mark.
Lastly, be careful of the Automatic Equalization mode of the Controller. Concord batteries require some specific charging requirements for equalizing (actually, Conditioning with AGM batteries) and it is different from how the Xantrex Controller performs the task. You charge the battery fully, and the Xantrex will raise the charge voltage to one volt above the normal bulk charge (in this case it would be 15.3 volts), but it will only run it at that voltage for one hour. But Concord Lifelines (and SunXtenders) require 15.6 volts for 8 hours. Also, the Xantrex will perform an equalization once a month if set to Auto, but Concord recommend conditioning the battery only when it begins to lose capacity. If you Condition them too often you will dramatically reduce the life of the battery. I'm pretty sure that the Xantrex defaults to Manual Equalization instead of Auto, though. Just something to be aware of. When performing a Manual Equalization, the voltage will remain at the elevated level for 2 hours, so when you do this you'll want to perform 4 cycles one right after the other to get the 8 hours in. Instead of once a month, more than likely once every 6 months will be fine, especially if you never discharge more than 50%. If your loads are low amp draws and you rarely go down below 80% or so, then you might not even need it as often as every 6 months. Concords that have not been boost-charged (Bulk) for several months, or have been operated in a partially charged or low state of charge for 90 days or more will probably need to be conditioned, but if you fully recharge the batteries on a regular basis, no need to condition them until you actually see a reduced capacity (which might be a year or two depending on your amp requirements).
So, basically, you're good to go with the setting you have, just keep a close eye on the DoD and make sure they are regularly recharged fully.
Bolt Express
Bolt Express
(800) 545-4789
Advertiser
