< 396.12 396.15 >
Related Links
Disclaimer
Interpretation
Help
Inspection, repair, and maintenance
§ 396.13Driver inspection.
Before driving a motor vehicle, the driver shall:
(a) Be satisfied that the motor vehicle is in safe operating condition;
(b) Review the last driver vehicle inspection report; and
(c) Sign the report, only if defects or deficiencies were noted by the driver who prepared the report, to acknowledge that the driver has reviewed it and that there is a certification that the required repairs have been performed. The signature requirement does not apply to listed defects on a towed unit which is no longer part of the vehicle combination.
396.9 396.12 >
Related Links
Disclaimer
Interpretation
Help
§ 396.11Driver vehicle inspection report(s).
(a) Equipment provided by motor carrier. (1) Report required.Every motor carrier shall require its drivers to report, and every driver shall prepare a report in writing at the completion of each day's work on each vehicle operated, except for intermodal equipment tendered by an intermodal equipment provider. The report shall cover at least the following parts and accessories:
(i) Service brakes including trailer brake connections;
(ii) Parking brake;
(iii) Steering mechanism;
(iv) Lighting devices and reflectors;
(v) Tires;
(vi) Horn;
(vii) Windshield wipers;
(viii) Rear vision mirrors;
(ix) Coupling devices;
(x) Wheels and rims;
(xi) Emergency equipment;
(2) Report content. The report shall identify the vehicle and list any defect or deficiency discovered by or reported to the driver which would affect the safety of operation of the vehicle or result in its mechanical breakdown. If no defect or deficiency is discovered by or reported to the driver, the report shall so indicate. In all instances, the driver shall sign the report. On two-driver operations, only one driver needs to sign the driver vehicle inspection report, provided both drivers agree as to the defects or deficiencies identified. If a driver operates more than one vehicle during the day, a report shall be prepared for each vehicle operated.
Sorry for the above but didn't want to get anything incorrect.
So pretrip is a quick walk around and verify that the previous dvir is showing no defects. Whatever time it takes you then you are good to go. Just remember that you are responsible for the condition of the equipment and can't say to DOT, I didn't know the tire was bald.....etc.
The DVIR is your thorough 15 minute minimum view of the equipment and a report.
**** each driver of the day MUST do a report at the end of their shift or before midnight east coast time****
Wife and I do our shifts 8 3 3 8 so 4 fast per trips and 2 dvirs and no 1/2 hour breaks needed
Others may do their shifts 11 then 11
2 fast pretrips 2 dvirs and 2 half hour breaks but you must get in the dvirs before midnite east coast time.....
That's my understanding and am open to any information that shows different.
