I have a single axle mack MS 200 and I want to change Rear end. Do I have to find a rear end out of a diesel or can I use a rear end out of a gas truck or if the gear ratio is the same it makes no difference. My ratio is 5.10 should I look for 5.10 or high or 5.10 or lower. What will a high one do and what will a lower one do to my truck.
I have a 5 speed trans with a Ranult 6 cyl diesel. If I go with a lower grar ratio will I loose power in 1st gear.
