CDL Requrements !
rmctt2
Hi guys;
This might sound like a stupid question but here goes it !!
What are the CDL reqirements to drive a Cargo Van verses a Straight Truck ?
Can one drive a van on regular DMV License ?
Thanks
rmctt2
redytrk
RE: CDL Requirements !
CDL for vans under 10,000 GVW is not required by the Dot unless transporting HAZMAT.
Most Expedite companies will require a CDL class "C" to allow for Hazmat loads.
fastman_1
Yes There are Carriers out there that will take you with no CDL
Owner/Operator since 1979
Expediter since 1997
B Unit Semi Retired
Somedays are Diamonds and Somedays are Stones
Home is Wherever you Park.
The Price of Freedom is Written on the Wall.
babs3361
I just read this. You only need a hazmat if it is a placarded load 2000 lbs is not placarded 2001 lbs is placarded. You need no CDL. For a straight truck you need a class B CDL with air brakes if equipment is so equipted and a hazmat endorsement. Any company requiring you to have one is just wasting your time and money. I Checked it out for our neighbor.
nobb4u
Just for your info...Hazmat loads are all different some will require you to placard any amount. So if you are going to haul anything that is listed as hazmat then you must have a hazmat endorsement.
If you haul non-placardable HAZMAT, meaning placardable in amounts greater than 1000 pounds (from a single shipper), but not placardable in lesser amounts, you still have to have a HAZMAT endorsement on your CDL.
Cargo van CDL's are Class C with either a HAZMAT or Passenger endorsement. A Class C without one or the other endorsement doesn't exist.
Incidentally, HAZMAT that is placardable in any amount (inhalation hazards, most poisons, explosives, etc.), generally cannot be carried in a cargo van.
