CAT 3126 Swap to Gas
ScottSTL
Hello, i'm new to this forum and currently have a 2000 GMC box truck with a CAT 3126. The truck is in the shop right now with a scored cylinder, i'm thinking of replacing it with a 454 Chevy just to get it moving again. The shop wants $15,000 for a rebuild on the 3126, i think i'll pass.
Has anyone done a swap like this before? I want to run my Allison if possible but not sure if it could be bolted up to the big block.
Also I plan on parting out the entire engine on ebay, so if anyone needs parts for a 3126, let me know!
Expeditus Transport
Expeditus Transport
(419) 464-7678
Advertiser
Straigt Truck - Owners !
We provide 24-7-365 service for CDL - Straight truck Owners Operators and Fleet owners. Run Over the Road - Regional - or Local in some areas ! If you have a Straight truck with a Sleeper that is what we are looking for . No Day cabsNo age requirement on the truck . -Must pass annual Dot .Join the Fleet that has the Best Dispatch , ... Apply Today!
guido4475
Is buying another truck out of the question?It would be alot easier, less time consuming, figuring the loss of income while doing the swap, ordering parts, etc.
zorry
If you don't have the big block why not buy engine-trans together. If you find your old trans is a match you've got a good spare. Or you can sell it.
ScottSTL
I'll probably be putting the truck up for sale if i do the swap. Or i'm considering selling the rolling chassis complete or parting the truck out as well.
ScottSTL
Just for the simple fact that big block's are cheap, the parts are cheap, and i can fix those easily instead of paying a shop as with the diesel. Most likely the truck will be up for sale once the swap is done.
Seeing it is a 2000, the best suggestion is to get A shop manual for it and see what is different. Chances are the cat ECM does more that any gas engine would.
ScottSTL
Could you explain this a bit more please?
I'm open to any suggestions...
I don't know what info your looking for. I mean that it all sounds easy to do but it could be a nightmare and long trail to walk.
The suggestion is to start with what you have, figure out what does what and go from there.
Give you an idea, the fl70 I have runs the insturment panel though the ECM and is "programed" for my engine.
zorry
I meant buy a gas engine hooked to a trans. You'll know it'll work. Then figure out what to do with present trans.
ScottSTL
Okay gotcha, yeah i didn't know about the instrument panel running off the ecm. That could definitely be a nightmare...
My goal was to get it running for cheap simply because the truck isn't worth that much and dropping a ton of money on a rebuild isn't cost effective for me.
ScottSTL
Yeah thats a good idea... i wonder how well a 4l80 pick up truck transmission would hold up?
I wouldn't consider anything less than a Allison 1000. The 4l80 is too light for that truck seeing it had a 3126
Ever consider a cummins isb?
cableguymn
several posts down from your parts post on CL.
2000 Freightliner FL70/FL80 for parts
Buy the engine out of that one.
If I was looking for a truck, the last thing I would want is a gas engine in it. You would be doing more damage to the value of the truck by switching to gas than if you just left the engine in it.
Ever thought of checking with a local diesel school? They do great work if your not in a hurry. Since your going to dump it after repairs I don't think it would be a huge deal to wait on it. You'll pay for parts, but the labor is free.
http://www.rockanddirt.com/search?l0=attachments&l1=CAT&l2=3126&l3=engines
Some running usable ones for 3500.. Probably be 500 to get it to you. As long as it runs well and your planing to sell. I'd dump one of those in. 4000 is likely what a 454 and conversion is going to cost you anyways.
You'll also have to check in to EPA laws. Dumping a gas engine in to a 2000 truck means all sorts of smog changes to get it up to snuff. The fines for selling it with out them (if someone complains) is nothing compared to the cost of a rebuild.
ScottSTL
Yeah i've sent that guy a few a emails, i need to go and take a look at the truck. Considering what my truck would be worth once its running has me concerned on even trying to attempt any kind of replacement engine project.
cableguymn
Sell the box/sleeper off it, sell the hood off it and junk the rest. :)
Or, buy a new truck with out a box/sleeper and put yours on it.
sewmun
I need a couple of 45 gal fuel for my FL70 & I might be interested in them if you bought the truck.
Expeditus Transport
Expeditus Transport
(419) 464-7678
Advertiser
