I tought I would pass this along. Found out that when you check belts and idlers, cat has a new front and back bearing assembly for the water pump belt. Mine were not in bad shape but added the new one since I had the belt already off. Suppose to be more balanced and last longer. I you take care of it a cat will go past 500,000. We have a 92 and it has 803,000 on it. It has had some minor repairs but no major overhaul ect. We currently have it as a spare truck hauling lumber. Took the box off and now its a flatbed. We have had better luck with cat than cummins. We had a cummins 250 in a fl70 and had nothing but problems. Primarily with the a/c compresser,( 5 in two years) and 3 a/c brackets. Not to mention belt and pulley problems. Kinda related. And, that was the engine, the cab was a piece of junk. We woke up and finally sold it and went to a KW. Smartest move we made!!!
