Nytmare897
I drive a 2006 Ford E-250 Cargo van that has a 2000 lbs Payload Capacity. What is the limit I should haul loads? 2100? 2500? What? Suggestions please.
Turtle, get an after market bucket extender and go for 8 gallons.
I think just a second bail with a plastic handle will do for 8 gallons. Over 8 gallons would probably require an extra leaf spring or another axle.Won't he have to add another leaf spring to the handle support system?
There is only one way to know for sure what your payload capacity is. Weigh your van with you on board and a full tank of fuel. Subtract that weight from the GVWR on the door frame tag.Are you sure that it says only 2000 lbs?
Ford and Chevy both made vans with several different weight ratings. Within the 250/2500 classification you had lightweights like the one the OP has to relative heavyweights like the one your friend has. The way you can tell what you have is the door plate. It tells you what YOUR VAN is capable of. Can you overload it (like your friend did) and get away with it? Sure, once in a while. It's not a good idea but it can be done. That 4,700 lb load took most of the spring travel (if not all of it) and put the engine under increased load, plus the brakes had to stop that heavier weight too. If he had gotten pulled over by LEO for any reason he would have been a sitting duck with that overload too. But--- every now and then you can get away with it.Are you sure that it says only 2000 lbs? Just asking because a friend of mine had a 2003 E-250 and the payload was somewhere close to 3000. And once, with the same van he hauled a 4700 lbs load from TX to OH...
If it's a yellow bucket, 12.I have a bucket with a 5 gallon capacity. How much should I put in there? 5 gallons? 6? 8?
If I were 35 again and knew what I know now.....
I'd get me a CHEAP CV and run the crap out of it...I'd run cheap , fast and heavy....when it broke down biggie repair that is.....toss it and get another....I Volume over quality..
