Brake week coming to you sept 8-14th
pearlpro
CVSA : CVSA Programs : Operation Air Brake
Inspectors will conduct more than 30,000 brake inspections across North America during the Commercial Vehicle Safety Alliance’s Brake Safety Week Sept. 8-14.
Inspectors from the Federal Motor Carrier Safety Administration and every CVSA jurisdiction primarily will do brake specific Level IV special study inspections, as well as some Level I inspections. During last year’s event, one of seven of 21,255 trucks and buses inspected were placed out-of-service.
CVSA conducts this enforcement and outreach campaigns on truck and bus brake safety each fall and an unannounced brake inspection blitz each spring. The alliance’s Operation Airbrake program supports this week, which is not limited to air breaks, but checking all breaks type and brake related technologies on commercial vehicles.
These upcoming inspections include a visual inspection to look for loose or missing parts, air or hydraulic fluid leaks, worn linings or pads, drums, rotors or other faulty brake system components.
They also will check antilock braking systems and malfunction indicator lamps. Where appropriate, they will visually inspect brake components and measure pushrod stroke.
The OOS rate for brake violations during the 2012 Brake Safety Week was 15.3 percent, slightly higher than the previous three years, but a little lower than for 2008 and 2007.
More information is available at operationairbrake.com.
Slo-Ride
Thanks for the heads up.
With out climbing under there right now I'm thinking only thing I should get done is to wipe down the inside of the wheels with mineral spirits and get the area/ wheels degreased if there is any build up..
Hoping that's all I need to do????
Jenny
Ta/petro had posted on their fb page about free midtrip inspections again. I dont remember the coupon code but I am sure they are well aware
Sent from my VS920 4G using Xparent Pink Tapatalk 2
Hmmm my truck has 4 wheel hydraulic disc brakes and the only way to check the pads is to pull the wheels, I had a flat the other day so my rears are in good shape and I had a tire mounted on the front 2 months ago and they were good too, just wonder how they are going to inspect trucks like mine.
15% OOS wow that's amazing that many trucks had brake issues.
xmudman
Hmmm my truck has 4 wheel hydraulic disc brakes....
I always wondered how they check hydraulic systems for brake issues (look for leaks/cracks/etc, I guess).
While I'm under a virtual truck, what DO they look for on an air system, anyway? Besides the obvious (slack adjusters, hissing lines, etc)...
zorry
If you have self adjusting, as has been standard for years, and you need to adjust them, your truck does have issues.
Plus it's a double whammy. You'll be written up for an out of adjustment brake AND a defective slack adjuster.
paullud
Keep in mind a crack in a pad despite not being a safety issue means you are OOS or ABS problems which aren't a safety issue can put you OOS.
moose
You have failed on the same spot as many truck safety haters have failed before.
the OOS rate is NOT per truck on the road- but for trucks inspected.
better yet for truck that the brake assembly was inspected.
so the roadside inspectors have a very efficient way of weeding out ALL of the trucks known to have good breaks. singling out ONLY trucks that are prawned to have break issues.
out of those 'bad actors' they only find 15% to be in violation of the law. as stated, most do not even pose a risk.
rest assure my friend that bad breaks on large trucks are a none issue nowdays.
Data manipulations is what the DOT. and safety advocates are good for.
Well got stopped at 2 scale houses and once they found out I had hydraulic brakes they looked at my log book real quick and said have a nice day.
pearlpro
Had an Inspection in Minnesota where they guy got his creeper, flashlite, and some kinda hammer and went under the truck and I heard BAM BAM and I came flying outta my cab, I got right down there and said you didnt just smack my brake drum with that hammer did you, He looked at me like UH OH...I asked what are you checking, and proceeded to tell him Brake drums are cast metal and hits from a hammer can cause fractures...he looked at me like a deer in the headlight and said I didnt know that....I proceeded to give him a Metallurgical explanation of fracturing Cast metal with a hammer blow as he wrote my papers out and said GOOD DAY....
tknight
i currently have a bent 90 on my exhaust from a hammer blow in New Jersey, if i had seen him do it i would have filed a complaint with njdot!
mjmsprt40
By a very strange coincidence, I am shut down for brakes. Not by the law-- it just happened. Broke a hydraulic line up in the left front, brakes got real "chancey" after that. Fortunately, I was able to get it in for repairs without anything bad happening. Funny that it should happen during "Brake Week" on a vehicle the DOT probably wouldn't have messed with. The "Gray Lady" will be back on the road later today or tomorrow in good order.
tknight
Just passed through Lodi oh scale and there were no fewer than 6 enforcement suv's and 8 Tractor trailers pulled in and red tagged
OOS with 3 waiting to be "inspected"
I hate that place!!!
