Box trucks
keithnel
I tried to post this yesterday, but it never showed up on the forum, so I am going to try again. Can one of the recruiters tell me if there are any national companies that allow Isuzu type box trucks to be used in OTR expediting. I know that there is no sleeper in them and that seems to be a draw back, but many cargo / sprinter vans do not have a sleeper either. Thanks for your help and input.
Keith
X1_SRH
That's a good question Keith, and I'm sure that this will shed a little light on the situation for you. CV's can get away without a sleeper because their Gross Vehicle Weight (GVW) is under 10,000 pounds. That means that they are not subject to the DOT's hours of service (HOS) regulations.
If you have a truck with a GVW greater than 10,000 and you have no sleeper, you may be required to show hotel receipts for your DOT mandated off duty time for the last 7 days. You can sleep at home, but you won't be home every night. You cannot legally sleep in your truck if you do not have a DOT approved sleeper.
What is a DOT approved sleeper you may ask????
The answer to that question and even more is available in the most recent copy of the federal motor carriers safety regulations book. They are available from any carrier and in most truck stops. The FMCSR is the rule book for our industry, and all commercial drivers should be familiar with its content.
Best of Luck - I hope this helps!
Scott
JohnMueller
Motor Carrier Executive
Safety & Compliance
Carrier Management
Sleeper Berth Requirements - see 49CFR 393.76
Thanks,
HotFr8SafetyDirector
Jefferson3000
Hey Keith,
Don't know if you got this note before. The post you are referring to was actually posted in the general section. You got a lot of info back from others there. But yes, the people you would need to discuss this with ultimately is a recruiter. Here is the other link:
http://www.expeditersonline.com/dcforum/DCForumID1/4174.html
Good luck! There are lots of good threads in the archives. Take the time and familiarize your self with issues already posted. You'll walk away with a lot.
Jeff
