CharlesD
I'm wondering how many of you are seeing higher rates with the higher fuel costs. It's becoming pretty hard to get a higher rate on any bid freight right now because it seems that the bidding hasn't increased enough to keep up with the fuel increases. Even on NLM where the surcharge is separated, what people are doing is cutting the line haul bid down lower so that when the surcharge is added the total rate is still what it was before. Basically, anywhere freight is subject to bidding, a carrier is hard pressed to even get $1.10 a mile on cargo van freight, more than that from 3PLs and other sources. If that was the going rate a month or two ago when fuel was cheaper, and it's still hard to get that now with the higher fuel, just what good is the fuel surcharge if people are just going to bid a lower linehaul to make the total rate the same? Drivers are saying they need more money because of higher fuel costs but if we bid higher we won't get the loads.
So I guess the question is are you getting a higher rate now with fuel prices higher, or is the linehaul getting cut as the surcharge goes up to keep your total rate the same? Or are the carriers just taking the hit right now on the profit margin by going lower on the linehaul and passing on the surcharge?
